[gdal-dev] Requesting gdal update to at least EPSG v8.6
Mary Jo Brodzik brodzik at nsidc.org
Fri May 8 16:09:24 PDT 2015
Hi, Even,
The directions for doing the update are way beyond my abilities. Is there
someone who can help produce the update?
I'm glad I can manually update the machine that I'm working with, but this
doesn't help the community of users who will be trying to read the data
that we are producing.  Many of them are intimidated by gdal tools, so
when I tell them how easy it will be for them to use gdal I'd really like
to give them the new epsg codes, instead of proj.4 strings.
Mary Jo
On Wed, 6 May 2015, Even Rouault wrote:
> Date: Wed, 6 May 2015 18:17:18 +0200
> From: Even Rouault <even.rouault at spatialys.com>
> To: Mary Jo Brodzik <brodzik at nsidc.org>
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Requesting gdal update to at least EPSG v8.6
> Le mercredi 06 mai 2015 18:01:59, Mary Jo Brodzik a écrit :
>> Bonjour, Even,  Merci for the quick response!
>> Unfortunately, I don't think v8.5 is good enough.  I worked with Roger
>> Lott late last year, and he made several corrections, including:
>> 1) New projection Conversion codes 6928, 6929, 6930
>> 2) New ProjectedCRS codes 6931, 6932 and 6933
> They aren't yet in the version that was imported.
> I'm moderately enthusiastic about redoing a new sync with latest EPSG database
> for just 3 codes, unless there's a strong demand from the community. You can
> workaround by manually adding in epsg.wkt the WKT definitions (old-style) of
> the PCS you're interested into.
> If anyone is willing to do the update, the procedure is described here :
> http://trac.osgeo.org/geotiff/browser/trunk/libgeotiff/csv/README
>> 3) Changed the state of deprecated codes 3973, 3974, 3975 to "Invalid"
>> because they were incorrect
>> 4) Edited descriptions for 3408, 3409 and 3410 to indicate they are
>> now superceded.
>> Roger did indicate that he had some of these in a patch release of EPSG
>> v.8.5.4, but that there were still some names and metadata that were
>> incorrect in 8.5.4 that were correctly released in v8.6.  From Roger:
>>> As far as the projection and CRS definitions are concerned everything is
>>> already OK in v8.5.4 in that coordinate conversions using CRSs 6931-33
>>> will be correctly implemented. It is only metadata (projection [but not
>>> CRS] names and projection and CRS remarks) that will change. As soon as
>>> we publish v8.6, v8.5.4 will no longer be available and the metadata you
>>> consider wrong will be lost to posterity.
>> Mary Jo
>>> Date: Wed, 6 May 2015 17:48:34 +0200
>>> Le mercredi 06 mai 2015 17:24:57, vous avez écrit :
>>>> Hello,
>>>> I would like to request that gdal be updated to use the latest EPSG
>>>> codes.
>>>> I worked with EPSG last year to correct some obsolete ProjectedCRS
>>>> definitions for some products I am developing, and I understand that the
>>>> corrected definitions were included in EPSG v8.6, released in Nov 2014.
>>>> I am unsure how to actually confirm the EPSG version included with gdal,
>>>> but I did find this trac ticket (http://trac.osgeo.org/gdal/ticket/5462)
>>>> that looks like you upgraded to epsg v8.4 in May 2014.
>>> Mary,
>>> GDAL 2.0 (currently in beta1) has been upgraded to EPSG v8.5. Isn't that
>>> good enough ? Which EPSG codes are you interested in ?
>>> Even
>>>> The EPSG web site at www.epsg-registry.org seems to indicate the latest
>>>> version may be 8.7.  I don't know what is new.  For my purposes and to
>>>> let my users know, v8.6 or better is what I need.
>>>> Thank you,
>>>> Mary Jo Brodzik
>>>> Mary Jo Brodzik, Senior Associate Scientist, 303-492-8263
>>>> NSIDC/CIRES, Univ. of Colo. at Boulder, 449 UCB, Boulder, CO 80309-0449
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
