[gdal-dev] create GeospatialPDF using Python
Luca Delucchi lucadeluge at gmail.com
Mon May 11 06:20:48 PDT 2015
On 21 April 2015 at 11:00, Jukka Rahkonen
<jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I would say "Yes, it may be a bug". If you would like to get a better answer
> you should show us a simple way to reproduce. In this case I think that an
> OGR_STYLE string with your gdal_translate command would be the minimum but
> even nicer would be to get also the raster and your faulty result file to
> compare with.
Sorry the late answer, data are here [0] (about 30MB) and this is the
gdal_translate -of PDF raster.pdf combine.pdf -co OGR_DATASOURCE=vector.pdf
> -Jukka Rahkonen-
[0] http://geodati.fmach.it/gfoss_geodata/test_pdf.zip
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
