[gdal-dev] Regarding DPI in Geospatial PDF
Vankadara, Sunil sunil.vankadara at hexagongeospatial.com
Tue May 12 23:21:31 PDT 2015
Hi Jukka,
Thanks for the detailed explanation. I could understand from your mail that changes in the DPI value will not affect the Page Size and PDF file size.
I am an amateur in this context, may I know what the user can achieve by providing different DPI values in creating a PDF file?
Regards
Sunil
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen
Sent: 11 May 2015 03:21:PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Regarding DPI in Geospatial PDF
Vankadara, Sunil <sunil.vankadara <at> hexagongeospatial.com> writes:
> Hi Team,
> I have created two PDF file with default DPI and 600 values using
gdal_translate application.
> Unfortunately I couldn't find any difference among these two created
> files
like file size, pixel size etc.
> The input file details are
> Input file type: Erdas . img file
> Width of the image: 11938
> Height of the image:: 14184
> Datatype: UINT 8
> No of Bands: 3
> May I know the reason for not showing up the difference in created outputs?
> Regards
> Sunil
It may be that DPI setting at the moment does not have a totally desired effect. It would feel natural that increasing DPI from the default value 72 into a bigger value like 300 would make the page size of the PDF smaller expressed as physical units like millimeters.
The DPI setting is not supposed to affect the image itself so the PDF file size will be the same as well as the image quality so no up/downsampling will occur.
You can read some background from http://trac.osgeo.org/gdal/ticket/5412. In older PDF versions there was an absolute limit that page could not be bigger than 14000 units and the unit size was fixed to 1/72 inch. This limitation can be overridden in later PDF versions by using a UserUnit.
Create some sample PDF files with gdal_translate and you can see how the user unit behaves by opening the PDF file with a text editor and having a look at row 4 in the file.
Without -co DPI
<< /Annots 6 0 R /Contents 4 0 R /MediaBox [ 0 0 1728 1977 ] /Parent 1 0 R /Resources 5 0 R /Type /Page /UserUnit 1 >>
With -co DPI=300
<< /Annots 6 0 R /Contents 4 0 R /MediaBox [ 0 0 414.72000000000008
474.48000000000008 ] /Parent 1 0 R /Resources 5 0 R /Type /Page /UserUnit
4.1666666666666661 >>
With -co DPI=600
<< /Annots 6 0 R /Contents 4 0 R /MediaBox [ 0 0 207.36000000000004
237.24000000000004 ] /Parent 1 0 R /Resources 5 0 R /Type /Page /UserUnit
8.3333333333333321 >>
The image box sixe comes from (MediaBox size) x (UserUnit size) and remains the same in all three cases because GDAL is adjusting both the MediaBox and UserUnit hand in hand.
It could be that GDAL should not touch to the size of the MediaBox if it does not exceed 14400 in either dimension.
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
