[gdal-dev] RE Python ogr GetFieldAsString problem
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu May 14 06:02:36 PDT 2015
Thanks for your responses!
We can't change the settings, Refused by the system admin, too many
applications are using the database and the actual settings.
The response of the WFS contains the comma, and it is in GML
 <gml:featureMember>
       <ms:SMDVDP_STAT_METE fid="SMDVDP_STAT_METE.2153">
         <ms:LONG_STAT>-64,2131</ms:LONG_STAT>
       </ms:SMDVDP_STAT_METE>
     </gml:featureMember>
The comma and decimals are not truncated by an XML validator, they are
truncated by GetFieldAsDouble
But Maybe, it thinks that there are 2 values...-64 and 2131.
On my side, A patch would be to replace the , by ., use GetFieldAsDouble
and replace . by , .....
Many countries in the world are using a comma as decimal separator there
must be a solution....
What do you think, Does GetFieldAsDouble should be able to manage the ,''?
thanks!
Even Rouault <even.rouault at spatialys.com>
2015-05-13 17:02
A
cc
gdal-dev at lists.osgeo.org
Objet
Re: [gdal-dev] RE Python ogr GetFieldAsString problem
Steve,
I believe comma as decimal separator is invalid for a XML double. Hence
the GML
driver only parses the value up to the comma. This could likely be
improved to
accept comma, but technically I believe a XML validator would reject this
GML.
Even
> More info.....
> ogr2ogr --version = GDAL 1.10.1, released 2013/08/26
> python --version = Python 2.7.3
> I have modified my script to get the field type
> while feat is not None:
>           feat_defn = layer.GetLayerDefn()
>           field_defn =
> feat_defn.GetFieldDefn(feat_defn.GetFieldIndex(attribut))
>           print field_defn.GetType()
>           if field_defn.GetType() == ogr.OFTReal:
>             print "%.4f" % feat.GetFieldAsDouble(attribut)
>           output.add(feat.GetFieldAsString(attribut))
>           feat = layer.GetNextFeature()
> It detects that it is a real, But GetFieldAsDouble also truncate the
value
> at the comma
> Steve Toutant/INSPQ/SSSS
> 2015-05-13 15:11
> A
> cc
> Objet
> I'm trying to parse a GML and read all the values of an attribute.
> Example
> <gml:featureMember>
> DescribeFeatureType for this layer returns
> <element name="LONG_STAT" minOccurs="0" type="double"/>
> wfs_ds = ogr.Open(tmp_file.name)  #tmp_file.name is the response of a
WFS
> getFeature request
> layer = wfs_ds.GetLayerByName('SMDVDP_STAT_METE ')
>           output.add(feat.GetFieldAsString('LONG_STAT'))
> (At runtime, the WFs, layer and attribute can be anything of any type.
And
> decimal separator, can be ',' or '.')
> The problem is that feat.GetFieldAsString('LONG_STAT') truncate the
string
> to the comma
> So instead of having -64,2131, I get -64 in the output
> What is the appropriate way to get the value of an attribute?
> thanks you!
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150514/cf0bdbd1/attachment-0001.html>
