[gdal-dev] Reading the TerrainBase 1995 dataset (.BIN + .HDR) with gdal?
Nikos Alexandris nik at nikosalexandris.net
Thu May 14 06:40:57 PDT 2015
Hi gdalers,
has anyone read the TerrainBase data set (NOOA, 1995) using gdal tools?
The link to the relevant CD is:
http://webapp1.dlib.indiana.edu/virtual_disk_library/index.cgi/6081153/FID3260
(see for example inside the DATA directory)
Thank you, Nikos
