[gdal-dev] GDAL no longer compile under Windows
Yuchen Zhong yuchen at avenza.com
Thu May 14 10:59:48 PDT 2015
Hello Even,
I tried with the latest version for today. It is working with my previous build script.
However, if I add DEBUG to it, it will give a lot of errors (different errors this time).
Here is an example:
reader_kompsat.cpp
reader_kompsat.cpp : fatal error C1033: cannot open program database 'c:\gdal200.pdb'
Generating Code...
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
Similarly, it was alright before May 2. I guess it is only partially fixed?
Yuchen
Sent from Mailbird [http://www.getmailbird.com/?utm_source=Mailbird&utm_medium=email&utm_campaign=sent-from-mailbird]
On 2015-05-14 11:40:59 AM, Even Rouault <even.rouault at spatialys.com> wrote:
Selon Yuchen Zhong :
> Hello Even,
> Basically, there are a number of files not found. I guess there must be an
> error in build script? I notice that gcore/makefile.vc was modified in that
> commit. It builds fine for the last commit on May 2, 2015.
> Here is an example of the error message (I also attached the entire compile
> log in this email for your reference):
> c1xx : fatal error C1083: Cannot open source file:
> 'gdaljp2metadatagenerator.cpp': No such file or directory
> Generating Code...
> Stop.
Yes that reminds me of the error that was fixed in a later revision. So svn
update.
> Best regards,
> Yuchen
> Sent from Mailbird
> > Hello all,
> > For some reason, GDAL no longer compile after this check in (commit) on May
> > 3rd, 2015:
> Yuchen
> "no longer compiles" is not precise enough. Please report the exact error
> messages.
> > Add imagery (satellite or aerial) metadata support (DigitalGlobe, GeoEye,
> > OrbView, Landsat, Pleiades, Resurs-DK1).
> > git-svn-id: https://svn.osgeo.org/gdal/trunk@29123
> > f0d54148-0727-0410-94bb-9a71ac55c965
> Did you try more recent revisions ? There was a temporary breakage that has
> been
> fixed in later revisions.
> The builds at http://archive.gisinternals.com/sdk/ succeeds with latest
> revisions
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150514/64baa20f/attachment.html>
