[gdal-dev] EarthWatch/DigitalGlobe .TIL format geotransform origin shifted
Dennis Gocke dengo at gmx.net
Fri May 15 04:48:32 PDT 2015
Hi Even,
thanks for confirming and fixing the issue.
Best Regards,
Dennis
On Fri, May 15, 2015 at 10:48 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Dennis,
> https://www.digitalglobe.com/sites/default/files/ISD_External.pdf indeed
> confirms your findings (page 37 & 38, doc of originX and ulX)
> Fixed per http://trac.osgeo.org/gdal/ticket/5961
> Even
> > Hey guys,
> > We have DigitalGlobe image strips which come with a *.til file.
> > The geotransform of the til and the separate images have a shift of half
> a
> > pixel when opened with GDAL.
> > The reason is that in the GDAL TIL driver the coordinates are treated as
> > outer pixel edge, where as it seems like they describe the pixel center,
> at
> > least in our cases.
> > Does  anyone know of a description for the TIL format to verify if the
> GDAL
> > driver or the TILs from DigitalGlobe are wrong?
> > For now we fixed it on our side, but you might consider changing the TIL
> > driver to treat the coordinates as pixel center.
> > Best Regards,
> > Dennis
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150515/f6a62378/attachment.html>
