[gdal-dev] match bounding box of two geometries of two different shape files
Hema Yeedunuri hema.yeedunuri at amigooptima.in
Fri May 15 05:19:32 PDT 2015
Hi All,
To be more clear I have attached better images that would explain problem.
I have to exactly fit the  vector img 1.png into vector image 2.png .I have
the 3.png where we can see that the two vectors doesnt fit properly i,e
1.png vector should exactly overlap on 2.png vector .How can it be done.
thanks,
Hema
On Fri, May 15, 2015 at 2:42 PM, Hema Yeedunuri <
hema.yeedunuri at amigooptima.in> wrote:
> Hi all ,
> I have two vectors one is of country (in black)and the other is
> corresponding states(in red) of the country.There is some variation with
> the overlaping of these two vectors as shown below.How should i match both
> the files so that the red one exactly falls on the black one .Please find
> the img in attachments
> thanks & regards,
> hema
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150515/08f4b784/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150515/08f4b784/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150515/08f4b784/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150515/08f4b784/attachment-0005.png>
