[gdal-dev] geospatialPDF DPI and EXTRA_IMAGES
Luca Delucchi lucadeluge at gmail.com
Tue May 19 01:12:46 PDT 2015
Hi devs,
I noticed something strange about the position of EXTRA_IMAGES with
different DPI values.
If I set a value lower than 73 the  EXTRA_IMAGE it is added in the
right place, but If I increase the value the EXTRA_IMAGE it is moved
up from the correct point.
Is this normal or a bug?
Is there any way to avoid this shift from the correct position?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
