[gdal-dev] ogr2ogr segfault
Paolo Cavallini cavallini at faunalia.it
Tue May 19 02:43:17 PDT 2015
Il 19/05/2015 11:18, Antonio Falciano ha scritto:
> ogr2ogr OUTPUTLAYER.shp strade.shp -dialect sqlite -sql "SELECT
> ST_Line_Interpolate_Point(geometry, 0.5), * FROM strade"
> What happens in this case?
Same thing, segfault.
Reading better notes from Debian developer I get convinced is the same
problem reported (not proj, sorry).
In fact:
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `ogr2ogr
/tmp/processing/ac237fb069174742838e3f468b7b8a28/OUTPUTLAYER.shp /home/'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x00007f9bfed4fff4 in spatialite_init () from
/usr/lib/x86_64-linux-gnu/libspatialite.so.5
Same thing as for qgis crashes.
Thanks for helping to understand.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
