[gdal-dev] RFC 58: Removing Dataset Nodata Value
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue May 19 07:31:52 PDT 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> I'm wondering if it might not make more sense to modify the input
driver(s) to
> not report out-of-range nodata values ? I fail to see a reason to report an
> out-of-range nodata value.
I wonder what happens for the nodata value if we convert images with GDAL
into types with more narrow range (32-bit -> 16-bit -> byte). Can the
out-of-range nodata values be our own creatures sometimes or do we handle
the case perfectly?
-Jukka Rahkonen-
