[gdal-dev] gdalwarp problems with MODIS L1B
Michael Sumner mdsumner at gmail.com
Wed May 20 03:34:57 PDT 2015
Hi Even, that is excellent, thank you.
I have one question about the resampling workaround:
On Wed, 20 May 2015 at 19:34 Even Rouault <even.rouault at spatialys.com>
wrote:
> Mike,
> > By my reading of https://trac.osgeo.org/gdal/wiki/rfc4_geolocate that
> means
> > the Geolocation tag from gdalinfo should have a PIXEL_STEP and LINE_STEP
> of
> > 5, and if I do this I get a much better result but it's still not right.
> I've just committed a patch in trunk that should put more sensible values
> for
> those values :
> r29212 "HDF4: ProcessModisSDSGeolocation(): set more correct values for
> PIXEL_/LINE_ OFFSET/STEP by comparing longitude and latitude subdatasets
> dimensions with main subdataset dimensions"
> > I've put a jpeg image of the result, with the coastline mapped and not
> > lining up, here:
> > http://staff.acecrc.org.au/~mdsumner/mod1.jpg
> Either the data itself is wrong, either there's an issue with the
> geolocation
> transformer... Later hypothesis is the more likely, although I've managed
> to
> make it work with L1B datasets where the tps or geoloc transformers gave
> roughly the same results.
> I've gotten smoother results by resizing the longitude&latitude
> subdatasets to
> the main subdataset dimension
> gdal_translate
> HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":1
> longitude.tif -outsize 1354 2030 -r cubic
> gdal_translate
> HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":0
> latitude.tif
> and then referencing them in the VRT produced with
> gdal_translate -of VRT
> HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":2 data.vrt
> (and then by correcting the offset and step values to 0 and 1 respectively)
Is this what occurs when warping generally? Or, even with your fix for
PIXEL/LINE STEP/OFFSET is present will it still be better to do these
external steps to improve the result?
Thanks again, I've really learnt a lot through this process.
Cheers, Mike.
> You might want to do the warp with -wo SAMPLE_GRID=YES -wo SAMPLE_STEPS=100
> too
> But overall the reprojected image stays roughly at the same location. This
> helps only removing a few artifacts on the edges.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150520/789743a7/attachment.html>
