[gdal-dev] Raster attribute tables in GDAL?
Even Rouault even.rouault at spatialys.com
Wed May 20 07:40:31 PDT 2015
Le mercredi 20 mai 2015 15:57:38, jramm a écrit :
> Does GDAL have any support for writing ESRI-style raster attribute tables?
> These are the .vat.dbf files that often accompany geotiffs and other
> formats....
I wasn't particularly aware of those sidecar files, but looking a bit I found
one sample at https://dl.vecnet.org/files/j67313813
It seems it is a standard .DBF file, so you can read/write it with the OGR
Shapefile driver.
Even
http://www.spatialys.com
