[gdal-dev] gdalwarp problems with MODIS L1B
Rutger kassies at gmail.com
Thu May 21 00:45:30 PDT 2015
Hey,
Maybe i'm missing something, but for as far as i know, the MODIS MOD021KM
product is still a 'swath', and therefore still containing the bow-tie
effect as the result of the scanning sensor. Wouldn't this mean that
gdalwarp will never work? The lat/lon arrays aren't continuous, so any
fitting (GCP/TPS) wont be accurate. And upsampling the arrays with cubic,
like Even did, will result in interpolating pixels which are next each other
in the array/file, but aren't next to each other 'on the ground', wont work
well.
I think you need to either use a dedicated algorithm (like gradient search),
or something very generic (like the KDTree of Pyresample) to overcome the
bow-tie effect.
I have spend alot of time experimenting with this in GDAL, since i try to do
as much with GDAL as possible. But projecting a swath file from a scanning
sensor (like MODIS or VIIRS) is something i have never gotten to work. For
some historic discussion about this see for example:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-reproject-python-numpy-binary-swath-lat-lon-td4978609.html
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdalwarp-problems-with-MODIS-L1B-tp5206583p5206825.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
