[gdal-dev] Raster attribute tables in GDAL?
James Ramm jamessramm at gmail.com
Thu May 21 06:18:57 PDT 2015
Scratch my last message, I should've read more carefully:
"Can be one of NULL for a simple .dbf file with no .shp file,"
On 21 May 2015 at 14:14, jramm <jamessramm at gmail.com> wrote:
> That sounds great. Does this driver allow you to only write the dbf file
> (and not the shp/shx etc files?)
> I can't find much on the docs for doing that:
> http://www.gdal.org/drv_shapefile.html
> I'll have a look through the header files...
> On 20 May 2015 at 15:38, Even Rouault-2 [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5206907&i=0>> wrote:
>> Le mercredi 20 mai 2015 15:57:38, jramm a écrit :
>> > Does GDAL have any support for writing ESRI-style raster attribute
>> tables?
>> > These are the .vat.dbf files that often accompany geotiffs and other
>> > formats....
>> I wasn't particularly aware of those sidecar files, but looking a bit I
>> found
>> one sample at https://dl.vecnet.org/files/j67313813
>> It seems it is a standard .DBF file, so you can read/write it with the
>> OGR
>> Shapefile driver.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> gdal-dev mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5206664&i=0>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp5206653p5206664.html
>>  To unsubscribe from Raster attribute tables in GDAL?, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Raster attribute tables in GDAL?
> <http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp5206653p5206907.html>
> Sent from the GDAL - Dev mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html> at
> Nabble.com.
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150521/2dad2d9c/attachment.html>
