[gdal-dev] Raster attribute tables in GDAL?
Even Rouault even.rouault at spatialys.com
Thu May 21 06:21:40 PDT 2015
Le jeudi 21 mai 2015 15:14:46, jramm a écrit :
> That sounds great. Does this driver allow you to only write the dbf file
> (and not the shp/shx etc files?)
Yes, if you create a layer with a None geometry type, no .shp,.shx will be
created.
> I can't find much on the docs for doing that:
> http://www.gdal.org/drv_shapefile.html
> I'll have a look through the header files...
Basically follow http://gdal.org/1.11/ogr/ogr_apitut.html "Writing to OGR" and
ignore what is related to geometries and pass wkbNone instead of wkbPoint when
calling CreateLayer()
> On 20 May 2015 at 15:38, Even Rouault-2 [via OSGeo.org] <
> ml-node+s1560n5206664h33 at n6.nabble.com> wrote:
> > Le mercredi 20 mai 2015 15:57:38, jramm a écrit :
> > > Does GDAL have any support for writing ESRI-style raster attribute
> > tables?
> > > These are the .vat.dbf files that often accompany geotiffs and other
> > > formats....
> > I wasn't particularly aware of those sidecar files, but looking a bit I
> > found
> > one sample at https://dl.vecnet.org/files/j67313813
> > It seems it is a standard .DBF file, so you can read/write it with the
> > OGR Shapefile driver.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > [hidden email] <http:///user/SendEmail.jtp?type=node&node=5206664&i=0>
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >  If you reply to this email, your message will be added to the discussion
> > below:
> > http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp520
> > 6653p5206664.html
> >  To unsubscribe from Raster attribute tables in GDAL?, click here
> > <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsub
> > scribe_by_code&node=5206653&code=amFtZXNzcmFtbUBnbWFpbC5jb218NTIwNjY1M3wy
> > MTIyMDM1OTQ5> .
> > NAML
> > <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro
> > _viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces
> > .BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.
> > template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.na
> > ml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aema
> > il.naml>
> http://osgeo-org.1560.x6.nabble.com/Raster-attribute-tables-in-GDAL-tp5206
> 653p5206907.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
