[gdal-dev] CSharp bindings question
Ari Jolma ari.jolma at gmail.com
Tue May 26 00:43:51 PDT 2015
Tamas,
I'm working on a cleanup of the bindings, trying to reduce the number of
language specifics in the common interface files.
I can test Python, Java, and Perl bindings well in my Linux machine but
can so far only generate and compile the CSharp wrappers. However, it
seems maybe possible with Mono. I installed mcs but I'm now stuck with
definitions with type
static OgrPINVOKE() {
appearing twice in OgrPINVOKE.cs and similar files. It seems that this
is not because of my changes so far - they appear also on trunk version.
The error message is
osr/OsrPINVOKE.cs(192,10): error CS0111: A member
`OSGeo.OSR.OsrPINVOKE.OsrPINVOKE()' is already defined. Rename this
member or use different parameter types
Do you have any idea what's going on and if it is even possible to
compile the CSharp bindings with Mono?
Bindings generation and compilation of the wrapper code is ok, the error
comes with command
mcs /debug:full /target:library /out:osr_csharp.dll osr/*.cs AssemblyInfo.cs
which is followed by
AssemblyInfo.cs(88,12): warning CS1699: Use compiler option `keyfile' or
appropriate project settings instead of `AssemblyKeyFile' attribute
before the error (above).
Regards,
Ari
