[gdal-dev] CSharp bindings question
Even Rouault even.rouault at spatialys.com
Tue May 26 01:38:09 PDT 2015
Le mardi 26 mai 2015 10:13:49, Tamas Szekeres a écrit :
> Hi Ari,
> I haven't tried to compile that with mono for quite a long time. I'll give
> it a try.
> However we did not follow the latest changes in the SWIG implementation
> with the bindings, so I'd try with an earlier version (ie. 1.3.39) to
> generate the wrappers.
I can confirm that I can compile the CSharp bindings on Linux with SWIG 1.3.40
(and run the tests), but I get the same error as Ari with SWIG 2.0.X
As far as I know, Java and Python bindings build and run equaly well with SWIG
1.3.40 or 2.0.X (although there's a Unix makefile hack to have Python 3.2
compat, conditionnaly applied with SWIG 1.3.40, that is no longer needed with
SWIG 2.0.4 or later)
> May be we should consider including the generated
> wrappers in gdal instead of let the users to use different versions with
> different results.
It would be good if we could have a common SWIG version that works for all the
bindings. So currently it seems to be 1.3.40 ?
Regarding putting the generated wrappers in SVN, that's already what we do for
Python. We could also just include the generated wrappers in the tarballs.
Even
http://www.spatialys.com
