[gdal-dev] Problem saving/reading inf GCPs values in VRT
Calogero Mauceri mauceri at actgate.com
Tue May 26 02:00:21 PDT 2015
Hi all,
we are having problems saving/reading GCPs values in a VRT file when
those values are inf or nan. This problem is happening on Window
platform while it is working as expected in unix systems.
We are setting the GCP values in a VRT dataset using the library
function GDALSetGCPs. The inf values get saved into the VRT XML as
"*1.#INF00000000E+000*" string
<GCPList Projection="PROJCS["unnamed",
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
             SPHEROID["WGS 84",6378137,298.257223563],
             TOWGS84[0,0,0,0,0,0,0]],
         PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
     PROJECTION["Orthographic"],
PARAMETER["latitude_of_origin",71.331088221],
PARAMETER["central_meridian",-156.63420306],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0]]">
     <GCP Id="0" Pixel="0.0000" Line="0.0000" X="*1.#INF00000000E+000*"
Y="*1.#INF00000000E+000*" />
     <GCP Id="1" Pixel="363.0000" Line="0.0000" X="-3.463981152302E+004"
Y="3.246591123662E+004" />
     <GCP Id="2" Pixel="725.0000" Line="0.0000" X="-1.070555064325E+004"
Y="1.097994383230E+004" />
     <GCP Id="3" Pixel="1088.0000" Line="0.0000"
X="-5.461709489401E+003" Y="6.277974169290E+003" />
     <GCP Id="4" Pixel="1450.0000" Line="0.0000"
X="-3.134437286904E+003" Y="4.191819043427E+003" />
   </GCPList>
when those values are read through the GDALGetGCPs library function,
then the inf values are set to 1.0.
Is this a bug in GDAL or are we setting the inf GCP values in the wrong way?
Note that on unix everything works fine, the inf values are saved as
"INF" strings in the VRT XML and they are properly converted when they
are read back.
Thanks in advance for your help.
     Calogero
Calogero Mauceri
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150526/b5dd0fff/attachment.html>
