[gdal-dev] Warning-free builds :-)
Even Rouault even.rouault at spatialys.com
Sun Nov 1 07:21:00 PST 2015
Le jeudi 29 octobre 2015 18:08:12, Even Rouault a écrit :
> Le jeudi 29 octobre 2015 17:59:52, Greg Troxel a écrit :
> > Even Rouault <even.rouault at spatialys.com> writes:
> > > Hi,
> > > We've achieved an important and symbolic milestone that will mean
> > > something to developers: most of our (Unix) builds are warning free
> > > (for the library + utilities) ! That is they pass with -Wall -Wextra
> > > -Werror compiler options. Not bad for a ~ 400 K effective line of code
> > > project ( ~ 800 K, with white lines + comments).
> > On which platforms and which CPU types?
> Some answers at the bottom of my first email
> > Hopefully this includes a build
> > on each of the 4 common BSDs and Illumos and perhaps OS X, and not only
> > i386 and amd64 but also a few things like sparc64 and arm.
> OS X as mentionned in my email, but I haven't tested other BSDs or Illumos
> (do people actually still use that beast...). Anyway people are welcome to
> test and provide fixes if there found issues. The Android build is a ARM
> one.
I've also added a big endian target with the armeb-linux-gnueabihf linaro
cross compilation chain :
https://github.com/rouault/gdal_coverage/blob/trunk_big_endian/.travis.yml
Only cross compilation tested.
http://www.spatialys.com
