[gdal-dev] Issues with GDAL compilation
Matthias Benedikt matthias.benedikt at boku.ac.at
Wed Nov 4 01:33:11 PST 2015
Hi there,
I'm trying to get GRASS and all its components compiled from source on a Scientific Linux 6.6. PROJ4, GEOS, netCFD and HDF5 are good to go, except GDAL.
What i did was:
cd /path/to/src
svn checkout https://svn.osgeo.org/gdal/branches/1.11/gdal gdal
cd /path/to/src/gdal
mkdir build
CFLAGS="-g -Wall" LDFLAGS="-s" ./configure \
--prefix=/path/to/src/gdal/build \
--with-png=internal \
--with-libtiff=internal \
--with-geotiff=internal \
--with-jpeg=internal \
--with-gif=internal \
--with-static-proj4=/path/to/src/proj-4.9.1/build \
--with-geos=/path/to/src/geos-3.4.2/build/bin/geos-config \
--with-hdf5=/path/to/src/hdf5-1.8.15-patch1/build \
--with-netcdf=/path/to/src/netcdf-4.3.3.1/build
make -j8
It keeps going a bit, but ends at some point with:
libtool: compile:  icpc -g -O2 -DHAVE_SSE_AT_COMPILE_TIME -Wall -I/path/to/src/gdal/port -I/path/to/src/gdal/gcore -I/path/to/src/gdal/alg -I/path/to/src/gdal/ogr -I/path/to/src/gdal/ogr/ogrsf_frmts -DHAVE_GEOS=1 -I/path/to/src/geos-3.4.2/build/include -DHAVE_AVX_AT_COMPILE_TIME -DOGR_ENABLED -I/path/to/src/gdal/port -I/path/to/src/netcdf-4.3.3.1/build/include -c gdalgrid.cpp  -fPIC -DPIC -o .libs/gdalgrid.o
": internal error: 010101_3007
( tel:0101013007)
compilation aborted for thinplatespline.cpp (code 4)
make[1]: *** [thinplatespline.lo] Error 1
make[1]: *** Waiting for unfinished jobs....
I compiled GDAL several times on Ubuntu systems, always worked out fine. Does anyone have any pointers what I'm doing wrong?
Best regards,
Matthias
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151104/b76dfb17/attachment.html>
