[gdal-dev] Current SVN doesn't build with VS
Kurt Schwehr schwehr at gmail.com
Fri Nov 13 11:22:58 PST 2015
Hi Joaquim,
I broke the build with https://trac.osgeo.org/gdal/changeset/31403/.  Even
created a ticket: https://trac.osgeo.org/gdal/ticket/6212 and I added your
error message to the ticket.
http://build.gisinternals.com/sdk/Default.aspx has been down, so it's been
tough to see what is happening.
It looks like with my latest fix that the max macro is indeed gone, but now
it looks like you are hitting trouble with C++11.  I've just submitted
https://trac.osgeo.org/gdal/changeset/31463 which might fix the issue.  Can
you do a svn update, try again and let me know what you get?
Thanks,
-kurt
On Fri, Nov 13, 2015 at 10:46 AM, Joaquim Luis <jluis at ualg.pt> wrote:
> The error is
> v:\gdal\frmts\hdf4\hdf4imagedataset.cpp(2386) : error C2784: '_Ty
> std::max(std::initializer_list<_Elem>,_Pr)' : could not deduce template
> argument for 'std::initializer_list<_Elem>' from 'int'
>         c:\program files (x86)\microsoft visual studio
> 12.0\vc\include\algorithm(4108) : see declaration of 'std::max'
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151113/4894aeb9/attachment.html>
