[gdal-dev] Current SVN doesn't build with VS
Joaquim Luis jluis at ualg.pt
Fri Nov 13 11:28:36 PST 2015
Hi Kurt,
I'll update but later. Now I have to go. Meanwhile I had replaced
std::max by MAX and it passed that point.
> Hi Joaquim,
> I broke the build with https://trac.osgeo.org/gdal/changeset/31403/.
> Even created a ticket: https://trac.osgeo.org/gdal/ticket/6212 and I
> added your >error message to the ticket.
> http://build.gisinternals.com/sdk/Default.aspx has been down, so it's
> been tough to see what is happening.
> It looks like with my latest fix that the max macro is indeed gone, but
> now it looks like you are hitting trouble with C++11.  I've just
> submitted https://>trac.osgeo.org/gdal/changeset/31463 which might fix
> the issue.  Can you do a svn update, try again and let me know what you
> get?
> Thanks,
> -kurt
> On Fri, Nov 13, 2015 at 10:46 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>> The error is
>> v:\gdal\frmts\hdf4\hdf4imagedataset.cpp(2386) : error C2784: '_Ty
>> std::max(std::initializer_list<_Elem>,_Pr)' : could not deduce template
>> argument for >>'std::initializer_list<_Elem>' from 'int'
>>        c:\program files (x86)\microsoft visual studio
>> 12.0\vc\include\algorithm(4108) : see declaration of 'std::max'
>> Joaquim
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151113/3a2a0e3a/attachment.html>
