[gdal-dev] No IDATs written into file
Ari Jolma ari.jolma at gmail.com
Sat Nov 14 14:12:24 PST 2015
The problem was that the source files of the virtual dataset were not
readable by the process that was running the web server in multi worker
mode (production mode) while I was running it myself in the debug mode
(single worker mode). The .vrt file was readable by all.
The virtual dataset did return an error code but I did not even get to
the point in my debugging where I could see from the code that it was a
simple not allowed to open those files - it was so deep. I could not see
the error message although I tried, it was lost at some point. I'll try
to understand why.
Best,
Ari
On 14.11.2015 18:59, Even Rouault wrote:
> Le samedi 14 novembre 2015 17:46:47, Ari Jolma a écrit :
>> I'm using the Translate function to clip tiles from a larger raster
>> using Perl bindings. I'm clipping into PNG files.
>> This is in a web service environment, i.e., several workers listening to
>> a client.
> Ari,
> Are the workers multi-threaded or each in their own process ?
> But even in the multi-threaded case, I can't reproduce with the following :
> #include "cpl_multiproc.h"
> #include "gdal_utils.h"
> #include "gdal.h"
> void copyFunc(void* arg)
>      const char* pszOut = (const char*)arg;
>      GDALDatasetH hSrcDS = GDALOpen("byte.tif", GA_ReadOnly);
>      char* argv[] = { "-of", "PNG", NULL };
>      GDALTranslateOptions* psOptions = GDALTranslateOptionsNew(argv, NULL);
>      GDALClose(GDALTranslate(pszOut, hSrcDS, psOptions, NULL));
>      GDALClose(hSrcDS);
>      GDALTranslateOptionsFree(psOptions);
> int main(int argc, char* argv[])
>      CPLJoinableThread *ht1, *ht2;
>      GDALAllRegister();
>      while(1)
>          ht1 = CPLCreateJoinableThread(copyFunc, "test1.png");
>          ht2 = CPLCreateJoinableThread(copyFunc, "test2.png");
>          CPLJoinThread(ht1);
>          CPLJoinThread(ht2);
> I assume your GDAL is built --with-threads (which is the default) if you use
> it in a multi-threaded context.
> Even
>> The Translate fails in pngwrite.c, in png_write_end with error
>> "No IDATs written into file".
>> The script works fine when I have only one worker.
>> I have tried writing the file into file system, VSI file system, etc.
>> The error is the same. The output seems to be consistently 33 bytes
>> long, i.e., only the header I guess.
>> I'm using unique file names.
>> Any ideas?
>> Ari
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
