[gdal-dev] Trying to debug a GDAL crash in "GDALClose(hDataset); "
Joaquim Luis jluis at ualg.pt
Sat Nov 14 16:41:12 PST 2015
Ok I went ahead I tried it myself. It doesn't crash on OSX
> My bad, I don't know how to produce a stack trace from within the VS
> debugger. I have it all visually but find no option to save it as a file.
> I added a breakpoint at  cpl_atomic_ops.cpp#L56 but it didn't stop there
> after the call to   GDALClose(hDataset);Actually when stepping in  it
> jumps directly from GDALClose() into CPLAtomicCompareAndExchange() but
> once there (due to crash) I can step back >to other functions.
> Sorry if it's not clear.
> Do you have a GMT build with GDAL svn? Could you please try if this
> crashes for you
> grdmath -Rd -I1 X = lixo.tiff:GTiff
> grdinfo -R0/20/30/50 lixo.tiff
>> nLockCount should be set by
>> https://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_priv.h#L598
>> https://trac.osgeo.org/gdal/browser/trunk/gdal/port/cpl_atomic_ops.cpp#L56
>> which uses InterlockedCompareExchange to change it.
>> Can you give the whole stack trace?
>> On Fri, Nov 13, 2015 at 6:47 PM, Joaquim Luis <jluis at ualg.pt> wrote:
>>> Hi,
>>> I'm having strange crashes in GDAL (SVN) when called via GMT. The
>>> crashes occur at a call to
>>> Now, this is only occurs when I try to read a sub-region of a grid but
>>> those are GMT details.
>>> It doesn't happen to colleagues on OSX but they are using gdal 1.11.
>>> Can't say that's the reason but this used to work for me as well on
>>> Windows >>>(I should know because I wrote that code).
>>> I built a GDAL debug and can see that the crash happens in
>>> cpl_atomic_ops.cpp
>>> int CPLAtomicCompareAndExchange(volatile int* ptr, int oldval, int
>>> newval)
>>>  return (LONG)InterlockedCompareExchange((volatile LONG*)(ptr),
>>> (LONG)newval, (LONG)oldval) == (LONG)oldval;
>>> because the 'ptr' is invalid. That function is called by
>>> gdalrasterblock.cpp
>>> GDALRasterBlock::DropLockForRemovalFromStorage()
>>>        if( CPLAtomicCompareAndExchange(&nLockCount, 0, -1) )
>>> and the debugger tells me that
>>>        nLockCount      <Unable to read memory>
>>> and here I'm lost. Where is nLockCount supposed to be set?
>>> Thanks
>>> Joaquim
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151115/4563fdb1/attachment.html>
