[gdal-dev] GetGCPs returns null
Bar Ori Ori.Bar at elbitsystems.com
Mon Nov 16 06:51:10 PST 2015
Hi all,
I wanted some explanations please about how to work with the GCPs.
I have an image and I want to save its corners coordinates (not a rectangle) as GCPs and not using the SetGeoTransform method which takes the upper-left coordinate and creates a rectangle based on it.
I accomplished it using the SetGCPs method. I even see that the IGEOLO field (I am working with NITF) is set correctly with those coordinates.
The problem is that I want to retrieve those coordinates for painting a footprint on a map I have.
I Tried the GetGCPs method but I got null. Also the GetGCPCount returns 0.
(I can get the data from the IGEOLO, but I prefer another solution, and in general to understand why GetGCPs returns nothing...)
Thanks.
[cid:image001.png at 01D1208E.FB1CD270]
Ori Bar | Software Developer
Applications Development
Elbit Systems Land and C4I
T  +972-9-8898900  |   M  +972-504-734296
The information in this e-mail transmission contains proprietary and business
sensitive information.  Unauthorized interception of this e-mail may constitute
a violation of law. If you are not the intended recipient, you are hereby
notified that any review, dissemination, distribution or duplication of this
communication is strictly prohibited. You are also asked to contact the sender
by reply email and immediately destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151116/550c7f02/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151116/550c7f02/attachment.png>
