[gdal-dev] OGR FileGDB fails to copy data
David Vick dvick at boundlessgeo.com
Tue Nov 17 14:36:29 PST 2015
I'm currently using OSGeo4W with ESRI's 1.4 version of the File Geodatabase
API and trying to ingest a filegdb into postgresql 9.2.2 that is configured
with ArcSDE and is using st_geometry as the default type.  When I execute
an ogr2ogr -update -append on a feature class that contains either
mulitlinestring or multipolygon I get an error that the copy statement
failed.  The debug info is listed below:
>ogr2ogr -update -append -preserve_fid -fieldmap identity -f "PostgreSQL"
PG:"host=******* user=**** dbname=******* port=5432 password=*****"
C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb AeronauticSrf_AM
--config PGSQL_OGR_FID "objectid" --config PG_USE_COPY "YES" --config
PG_USE_BASE64 "YES" --config FGDB_BULK_LOAD "YES" --config
PG_LIST_ALL_TABLES "YES" --config OGR_TRUNCATE "YES" --debug ON -progress
FileGDB: Really opening C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb
OGR: OGROpen(C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb/03B3D220)
succeeded as FileGDB.
PG: DBName="fgcmdev3wk"
PG: PostgreSQL version string : 'PostgreSQL 9.2.2 on
x86_64-unknown-linux-gnu, compiled by gcc (GCC) 4.4.6 20110731 (Red Hat
4.4.6-3), 64-bit'
PG: PostGIS version string : '2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
OGR: OGROpen(PG:host=lnsvr0800.gcsd.harris.com user=fgcm dbname=fgcmdev3wk
port=5432 password=fgcm/054050E8) succeeded as PostgreSQL.
PG: Using column 'objectid' as FID for table 'aeronauticsrf_am'
PG: Field shape is of unknown format type st_geometry (type=st_geometry).
0...10...20...30...40...50...60...70...80...90...100 - done.
PG: PQputCopyEnd()
ERROR 1: COPY statement failed.
ERROR:  ESRI: invalid hexa character in hexa string [30000]:
CONTEXT:  COPY aeronauticsrf_am, line 1, column shape:
"{C8CDC53F-9478-4CB9-9CD3-7ADA9558FFC2}"
OGR2OGR: 118 features written in layer 'aeronauticsrf_am'
FileGDB: ref_count of C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb =
0 now
FileGDB: Really closing C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb
now
Does anyone have any other suggestions to try?  Our current process of
loading data is taking in excess of 12 hours and getting ogr2ogr to work
will improve this time to just minutes.
Thank you,
David Vick
Professional Services Engineer | Boundless <http://www.boundlessgeo.com>
mobile: 1-636-698-3174
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151117/bb7912e4/attachment.html>
