[gdal-dev] OGR FileGDB fails to copy data
David Vick dvick at boundlessgeo.com
Thu Nov 19 08:18:17 PST 2015
Evan,
I wanted to circle back to you and thank you for the suggestion regarding
"fieldmap identity".  It turns out this was indeed the problem.  I was
convinced that it needed to be used to ensure that the domains and
sub-types of the filegeodatabase were transferred.
Thanks again!
David Vick
Professional Services Engineer | Boundless <http://www.boundlessgeo.com>
mobile: 1-636-698-3174
On Tue, Nov 17, 2015 at 7:12 PM, David Vick <dvick at boundlessgeo.com> wrote:
> Evan,
> Thanks for the reply.
> We are using gdal 1.11, I have tried with setting PG_USE_COPY=NO and
> -skipfailures yields no results as all features within the layer fail.  I
> will try without the -fieldmap identity, but doubt that will have any
> effect as the schema of the the file geodatabase is copied into postgis
> prior to running ogr2ogr.
> I have tried the OGR_TRUNCATE "YES" --config option and using -overwrite
> deletes the schema that we need as part of our business process.
> Yes there is an ESRI column, the geometries are stored in the "shape"
> column in the db as we are currently tied to using ESRI's st_geometry as
> part of the business process.  If we could use postgis' native geometry
> this ogr2ogr process would be a perfect fit.
> I will try the ingest again without the -fieldmap identity parameter to
> see if it makes a difference.  Thanks again, and please reach out if you
> think of anything else.
> David Vick
> On Tue, Nov 17, 2015 at 4:55 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le mardi 17 novembre 2015 23:36:29, David Vick a écrit :
>> > Hi,
>> > I'm currently using OSGeo4W with ESRI's 1.4 version of the File
>> Geodatabase
>> > API and trying to ingest a filegdb into postgresql 9.2.2 that is
>> configured
>> > with ArcSDE and is using st_geometry as the default type.  When I
>> execute
>> > an ogr2ogr -update -append on a feature class that contains either
>> > mulitlinestring or multipolygon I get an error that the copy statement
>> > failed.  The debug info is listed below:
>> > >ogr2ogr -update -append -preserve_fid -fieldmap identity -f
>> "PostgreSQL"
>> > PG:"host=******* user=**** dbname=******* port=5432 password=*****"
>> > C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb AeronauticSrf_AM
>> > --config PGSQL_OGR_FID "objectid" --config PG_USE_COPY "YES" --config
>> > PG_USE_BASE64 "YES" --config FGDB_BULK_LOAD "YES" --config
>> > PG_LIST_ALL_TABLES "YES" --config OGR_TRUNCATE "YES" --debug ON
>> -progress
>> > FileGDB: Really opening
>> > OGR:
>> OGROpen(C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb/03B3D220)
>> > succeeded as FileGDB.
>> > PG: DBName="fgcmdev3wk"
>> > PG: PostgreSQL version string : 'PostgreSQL 9.2.2 on
>> > x86_64-unknown-linux-gnu, compiled by gcc (GCC) 4.4.6 20110731 (Red Hat
>> > 4.4.6-3), 64-bit'
>> > PG: PostGIS version string : '2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
>> > OGR: OGROpen(PG:host=lnsvr0800.gcsd.harris.com user=fgcm
>> dbname=fgcmdev3wk
>> > port=5432 password=fgcm/054050E8) succeeded as PostgreSQL.
>> > PG: Using column 'objectid' as FID for table 'aeronauticsrf_am'
>> > PG: Field shape is of unknown format type st_geometry
>> (type=st_geometry).
>> > 0...10...20...30...40...50...60...70...80...90...100 - done.
>> > PG: PQputCopyEnd()
>> > ERROR 1: COPY statement failed.
>> > ERROR:  ESRI: invalid hexa character in hexa string [30000]:
>> > CONTEXT:  COPY aeronauticsrf_am, line 1, column shape:
>> > "{C8CDC53F-9478-4CB9-9CD3-7ADA9558FFC2}"
>> > OGR2OGR: 118 features written in layer 'aeronauticsrf_am'
>> > FileGDB: ref_count of
>> C:\Users\dvick99\Documents\fgcm\TDS61_Merged_FJ.gdb =
>> > 0 now
>> > FileGDB: Really closing
>> > now
>> > Does anyone have any other suggestions to try?  Our current process of
>> > loading data is taking in excess of 12 hours and getting ogr2ogr to work
>> > will improve this time to just minutes.
>> David,
>> Difficult to know what happens with just that.
>> Which GDAL version ?
>> You could try without PG_USE_COPY=YES to check if it is an issue with the
>> copy
>> mode.
>> And -skipfailures to identify if there's a particular feature that cause
>> problem or if it is more general.
>> Perhaps a field mismatch with "-fieldmap identity" ? This option only
>> works if
>> the column names in source and target datasets are listed in same order
>> (check
>> with ogrinfo)
>> Did you try creating a new target layer instead of -update + --config
>> OGR_TRUNCATE "YES"  ?
>> I'm not sure when the error "ERROR:  ESRI: invalid hexa character in hexa
>> string [30000]:" comes from. Is there a 'ESRI' column ?
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151119/60a3d5de/attachment.html>
