[gdal-dev] Proposed Block iterator API
Even Rouault even.rouault at spatialys.com
Fri Nov 20 13:35:31 PST 2015
I was wondering if there wasn't a need for a block iterator API for code that
wants to process raster efficiently and iterates over blocks from top to bottom,
and left to write. Currently you have to create 2 for loops and deal with
partial blocks at edges (see
https://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/rasterio.cpp#L3576).
Nothing really fundamentaly complicated, but I guess people have to often
write that boring code and I'm sure there a lot of occurences of it inside
GDAL itself. The API just returns the coordinates of the window, but doesn't
do the pixel queries (people could use it to operate on a single band, or
multiple bands)
An example on how to use the API is :
int main(int argc, char* argv[])
    GDALAllRegister();
    GDALDatasetH hDS = GDALOpen(argv[1], GA_ReadOnly);
    GDALBlockIteratorH hIter = GDALCreateBlockIterator(
                                                  GDALGetRasterBand(hDS, 1));
    int nXOff, nYOff, nXSize, nYSize;
    while( GDALBlockIteratorGetNext(hIter, &nXOff, &nYOff, &nXSize, &nYSize) )
        double dfProgressStart, dfProgressEnd;
        dfProgressStart = GDALBlockIteratorGetProgress(hIter, &dfProgressEnd);
        printf("nXOff=%d nYOff=%d nXSize=%d nYSize=%d [%.2f->%.2f]\n",
               nXOff, nYOff, nXSize, nYSize, dfProgressStart, dfProgressEnd);
    GDALDestroyBlockIterator(hIter);
    GDALClose(hDS);
    return 0;
And if you run it on a 20x20 raster with blocks of size 16x16, it will
display:
nXOff=0 nYOff=0 nXSize=16 nYSize=16 [0.00->64.00]
nXOff=16 nYOff=0 nXSize=4 nYSize=16 [64.00->80.00]
nXOff=0 nYOff=16 nXSize=16 nYSize=4 [80.00->96.00]
nXOff=16 nYOff=16 nXSize=4 nYSize=4 [96.00->100.00]:
Thoughts ?
Best regards,
Even
PS: below the API and its implementation
#include <gdal_priv.h>
/* API */
CPL_C_START
typedef struct GDALBlockIterator *GDALBlockIteratorH;
GDALBlockIteratorH CPL_DLL GDALCreateBlockIterator(GDALRasterBandH hBand);
void CPL_DLL GDALDestroyBlockIterator(GDALBlockIteratorH hIter);
int CPL_DLL GDALBlockIteratorGetMaxXSize(GDALBlockIteratorH hIter);
int CPL_DLL GDALBlockIteratorGetMaxYSize(GDALBlockIteratorH hIter);
void GDALBlockIteratorSetBlockSize(GDALBlockIterator* poIter, int nBlockWidth,
int nBlockHeight);
int CPL_DLL GDALBlockIteratorGetNext(GDALBlockIteratorH hIter,
                                     int* pnXOff,
                                     int* pnYOff,
                                     int* pnXSize,
                                     int* pnYSize);
double CPL_DLL GDALBlockIteratorGetProgress(GDALBlockIteratorH hIter, double*
pdfNextProgress);
CPL_C_END
/* Impl */
    int nXSize;
    int nYSize;
    int nXOff;
    int nYOff;
    int nBlockWidth;
    int nBlockHeight;
    bool bFinished;
typedef struct GDALBlockIterator GDALBlockIterator;
GDALBlockIterator* GDALCreateBlockIterator(GDALRasterBandH hBand)
    GDALRasterBand* poBand = (GDALRasterBand*)hBand;
    GDALBlockIterator* poIter = new GDALBlockIterator;
    poIter->nXSize = poBand->GetXSize();
    poIter->nYSize = poBand->GetYSize();
    poBand->GetBlockSize( &(poIter->nBlockWidth), &(poIter->nBlockHeight) );
    poIter->nXOff = -1;
    poIter->nYOff = 0;
    poIter->bFinished = false;
    return poIter;
void GDALDestroyBlockIterator(GDALBlockIteratorH hIter)
    delete hIter;
int GDALBlockIteratorGetMaxXSize(GDALBlockIterator* poIter)
    return poIter->nBlockWidth;
int GDALBlockIteratorGetMaxYSize(GDALBlockIterator* poIter)
    return poIter->nBlockHeight;
int nBlockHeight)
    poIter->nBlockWidth = nBlockWidth;
    poIter->nBlockHeight = nBlockHeight;
int GDALBlockIteratorGetNext(GDALBlockIterator* poIter,
                             int* pnXOff,
                             int* pnYOff,
                             int* pnXSize,
                             int* pnYSize)
    if( poIter->bFinished )
        return FALSE;
    if( poIter->nXOff < 0 )
        poIter->nXOff = 0;
    else
        poIter->nXOff += poIter->nBlockWidth;
    if( poIter->nXOff >= poIter->nXSize )
        poIter->nXOff = 0;
        poIter->nYOff += poIter->nBlockHeight;
        if( poIter->nYOff >= poIter->nYSize )
            poIter->bFinished = true;
            return FALSE;
    if( pnXOff )
        *pnXOff = poIter->nXOff;
    if( pnYOff )
        *pnYOff = poIter->nYOff;
    if( pnXSize )
        *pnXSize = poIter->nBlockWidth;
        if( poIter->nXOff + poIter->nBlockWidth >= poIter->nXSize )
            *pnXSize = poIter->nXSize - poIter->nXOff;
    if( pnYSize )
        *pnYSize = poIter->nBlockHeight;
        if(poIter->nYOff + poIter->nBlockHeight >= poIter->nYSize )
            *pnYSize = poIter->nYSize - poIter->nYOff;
    return TRUE;
double GDALBlockIteratorGetProgress(GDALBlockIterator* poIter, double*
pdfNextProgress)
        if( pdfNextProgress != NULL )
            *pdfNextProgress = 100.0;
        return 100.0;
    int nBlockHeight = poIter->nBlockHeight;
    if( poIter->nYOff + nBlockHeight > poIter->nYSize )
        nBlockHeight = poIter->nYSize - poIter->nYOff;
    double dfProcessedPixels = (double)poIter->nYOff * poIter->nXSize + poIter-
>nXOff * nBlockHeight;
    double dfRet = 100.0 * dfProcessedPixels / poIter->nXSize / poIter-
>nYSize;
        GDALBlockIterator sIterDup = *poIter;
        GDALBlockIteratorGetNext(&sIterDup, NULL, NULL, NULL, NULL);
        *pdfNextProgress = GDALBlockIteratorGetProgress(&sIterDup, NULL);
    return dfRet;
http://www.spatialys.com
