[gdal-dev] unable to open DGN
Brad Hards bradh at frogmouth.net
Fri Nov 20 13:40:03 PST 2015
On Fri, 20 Nov 2015 02:20:55 PM Martin Landa wrote:
> I am trying to open sample DGN file, but it fails. I guess that the
> reason is unsupported version (man pages says: Microstation DGN files
> from Microstation versions predating version 8.0 are supported for
> reading.)
As I understand it, version 8 is completely different.
> Is there any possibility how to read this file using GDAL library?
AFAICT, not unless you figure out version 8 format and implement it, or pay
someone to do that work for you. Is it possibly to get the originator to
provide it in some other format (e.g. DXF, noting that will lose the
georeferencing)?
Brad
