[gdal-dev] Reading DNC nautical charts
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Nov 21 21:48:54 PST 2015
If you have a link to the charts, I could look at it and see the format and see if they are georeferenced (if coordinates like longitude and latitudes is included in the image file).  They should be.  If so, I would recommend you use a GIS software like QGIS to visualise the maps  and manipulate the map.  QGIS has plugins that will permit you to plug in a GPS and to track the movement for navigation.
 QGIS uses the GDAL library to open, save and manipulate maps images (rasters)  and point, line and polygons (vector data) so you get all the power of GDAL and a user friendly interface.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Nov 20, 2015 4:13 PM, Hans Rijsdijk <hrijsdijk at gmail.com> wrote:
> Can anyone advise if DNC nautical charts can be used on the gdal software and, if so even better with a gps? In other words for navigation.
> I am not familiar with gdal software so a 'fatherly' response will be greatly appreciated.
> Cheers
> Hans
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
