[gdal-dev] Two versions of gdal
Ivan Lucena lucena_ivan at hotmail.com
Mon Nov 23 06:19:10 PST 2015
You don't need to build two gdal versions.
You can build GDAL (libgal.so) without the driver and then you build the driver as a plugin (ogr_FileGDB.so).
./configure -without-fgdb
make
./configure -with-fgdb
make
You can choose to use the drive, or not, by managing the GDAL_DRIVER_PATH environment variable.
The advantage is that libgdal.so is not going to depend on FileGDB SDK.
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Gane R <gane.prog at gmail.com>
Sent: Monday, November 23, 2015 8:24 AM
To: Even Rouault; gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Two versions of gdal
I have a requirement of two version of gdal one with filegeodb (gdal 2.0.1) and other without filegeodb (gdal 2.0.1) on linux, any references how this can make co exist ?
thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151123/d32db940/attachment.html>
