[gdal-dev] Ingesting ESRI geometry into PostGIS
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 23 10:41:04 PST 2015
This is a non-sequitur "PostgreSQL/PostGIS that has the default geometry_storage parameter set to st_geometry”. The ST_Geometry type is an ESRI thing, and you need to have ESRI dll’s installed in your PostgreSQL/ESRI server in order to create such a column. That’s Problem #1.
Problem #2 is that GDAL doesn’t support writing to a PostgreSQL/ESRI database, so you’ll have to write a suitable driver for that.
ATB,
P.
On November 23, 2015 at 10:34:28 AM, David Vick (dvick at boundlessgeo.com) wrote:
All,
I'm trying to use ogr2ogr to ingest FileGDB's into PostgreSQL/PostGIS that has the default geometry_storage parameter set to st_geometry.  When running ogr2ogr with DEBUG on I see a message PG: Field shape is of unknown format type st_multipolygon <type=st_multipolygon> ogr2ogr completes and I can verify that the data is copied into postgis, but the geometries are NOT copied over.  Does anyone have an idea on how to resolve this?
Thanks,
David Vick
Professional Services Engineer | Boundless
mobile: 1-636-698-3174
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Paul Ramsey
Sent with Airmail
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151123/98bebafa/attachment.html>
