[gdal-dev] strange grid pattern when reprojecting
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 27 03:25:11 PST 2015
Gdalwarp is the tool to use and usually it works well but your case is not the most common one "lunar south polar DEMs in stereographic projection to gnomonic projection." Best if you could put a sample image available somewhere but perhaps but there are some documents about advanced tricks like https://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp. I would test -et 0.
-Jukka Rahkonen-
Ramiro wrote:
I've tried all the resampling methods and all of them produce a gridded
pattern. Is there any other way of reprojecting the data using gdal?
Cheers,
Ramiro
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151127/4366ebfc/attachment.html>
