[gdal-dev] Geometry not displayed with Filegeodb on GDAL 2.0.1
Gane R gane.prog at gmail.com
Fri Nov 27 05:58:09 PST 2015
I figured out the issue this was due to wrong API call.
Thanks
Gane
On Mon, Nov 23, 2015 at 9:59 PM, Gane R <gane.prog at gmail.com> wrote:
> Hi all,
> I tried to build *GDAL 2.0.1* with *filegeodb* support with *proj4* as
> static lib on *Linux*. I am able to use the API to get the field data from
> Filegeodb but I am *not able to get the geometry*.  I have configured as
> ./configure --with-fgdb=/fgdblib --with-static-proj4=/usr/local/
> --with-xml2=no --with-sqlite3=no --with-curl=no --with-expat=no
> I am wondering what went wrong. But ogrinfo shows the values of the same
> filegeodb file.
> Thanks
> Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151127/8b26bfcc/attachment.html>
