[gdal-dev] Problem building GDAL on Ubuntu
David Adler dadler at adtechgeospatial.com
Sun Nov 29 04:18:52 PST 2015
For the first time I am trying to do development on an Ubuntu system.
After installing various tools, checking out the trunk source and
configuring, make appears to compile all the source ok but fails in
libtool with the following messages:
make[1]: Entering directory `/home/davea/gdal'
/bin/bash /home/davea/gdal/libtool --mode=link    g++   -lpthread -lm
-lrt -ldl                     -o libgdal.la
/home/davea/gdal/frmts/o/*.lo /home/davea/gdal/gcore/*.lo
/home/davea/gdal/port/*.lo /home/davea/gdal/alg/*.lo
/home/davea/gdal/apps/commonutils.lo
/home/davea/gdal/apps/gdalinfo_lib.lo
/home/davea/gdal/apps/gdal_translate_lib.lo
/home/davea/gdal/apps/gdalwarp_lib.lo
/home/davea/gdal/apps/ogr2ogr_lib.lo
/home/davea/gdal/apps/gdaldem_lib.lo
/home/davea/gdal/apps/nearblack_lib.lo
/home/davea/gdal/apps/gdal_grid_lib.lo
/home/davea/gdal/apps/gdal_rasterize_lib.lo
/home/davea/gdal/ogr/ogrsf_frmts/o/*.lo ./ogr/ogrgeometryfactory.lo
./ogr/ogrpoint.lo ./ogr/ogrcurve.lo ./ogr/ogrlinestring.lo
./ogr/ogrlinearring.lo ./ogr/ogrpolygon.lo ./ogr/ogrutils.lo
./ogr/ogrgeometry.lo ./ogr/ogrgeometrycollection.lo
./ogr/ogrmultipolygon.lo ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo
./ogr/ogrmultilinestring.lo ./ogr/ogrcircularstring.lo
./ogr/ogrcompoundcurve.lo ./ogr/ogrcurvepolygon.lo
./ogr/ogrcurvecollection.lo ./ogr/ogrmulticurve.lo
./ogr/ogrmultisurface.lo ./ogr/ogr_api.lo ./ogr/ogrfeature.lo
./ogr/ogrfeaturedefn.lo ./ogr/ogrfeaturequery.lo
./ogr/ogrfeaturestyle.lo ./ogr/ogrfielddefn.lo
./ogr/ogrspatialreference.lo ./ogr/ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo
./ogr/ogr_fromepsg.lo ./ogr/ogrct.lo ./ogr/ogr_opt.lo
./ogr/ogr_srs_esri.lo ./ogr/ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo
./ogr/ogr_srs_dict.lo ./ogr/ogr_srs_panorama.lo ./ogr/ogr_srs_ozi.lo
./ogr/ogr_srs_erm.lo ./ogr/swq.lo ./ogr/swq_expr_node.lo
./ogr/swq_parser.lo ./ogr/swq_select.lo ./ogr/swq_op_registrar.lo
./ogr/swq_op_general.lo ./ogr/ogr_srs_validate.lo ./ogr/ogr_srs_xml.lo
./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo
./ogr/gml2ogrgeometry.lo ./ogr/ogr_expat.lo ./ogr/ogrpgeogeometry.lo
./ogr/ogrgeomediageometry.lo ./ogr/ogr_geocoding.lo ./ogr/osr_cs_wkt.lo
./ogr/osr_cs_wkt_parser.lo ./ogr/ogrgeomfielddefn.lo ./ogr/ograpispy.lo \
         -rpath /usr/local/lib \
         -no-undefined \
         -version-info 20:0:0
libtool: link: unable to infer tagged configuration
libtool: link: specify a tag with `--tag'
make[1]: *** [libgdal.la] Error 1
make: *** [check-lib] Error 2
Did I miss something in the setup process?
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
