[gdal-dev] Problem building GDAL on Ubuntu - solved
David Adler dadler at adtechgeospatial.com
Sun Nov 29 06:40:17 PST 2015
Thank you for the quick response on a Sunday morning.
I'm using Ubuntu 14.04 LTS. The problem was as described in the
referenced ticket - I didn't see the error when running ./configure.
It all seems to work now.
On 11/29/2015 7:28 AM, Even Rouault wrote:
> Le dimanche 29 novembre 2015 13:18:52, David Adler a écrit :
>> For the first time I am trying to do development on an Ubuntu system.
> Which Ubuntu version ?
>> After installing various tools, checking out the trunk source and
>> configuring, make appears to compile all the source ok but fails in
>> libtool with the following messages:
>> libtool: link: unable to infer tagged configuration
>> libtool: link: specify a tag with `--tag'
>> make[1]: *** [libgdal.la] Error 1
>> make: *** [check-lib] Error 2
>> Did I miss something in the setup process?
> There's an old ticket somehow related:
> https://trac.osgeo.org/gdal/ticket/4436
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
