[gdal-dev] MDB tools
Stefan Keller sfkeller at gmail.com
Fri Oct 2 10:54:12 PDT 2015
2015-10-02 16:35 GMT+02:00 I wrote
> Yes, I'm testing GDAL 1.11.2, released 2015/02/10, in Windows which
> supports PGeo and Geomedia.
> My problem is, how can I tell ogrinfo's and ogr2ogr that myfile.mdb is
> Geomedia and not PGeo (since both have fileextension .mdb)?
That's the command and the error messages I get:
C:\Users\sfkeller\Downloads>ogrinfo fussgaengerstreifen.mdb -al -so
ERROR 1: Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access
 Driver (*.mdb);DBQ=fussgaengerstreifen.mdb,
[Microsoft][ODBC Driver Manager] Data source name not found and no default drive
r specified
r specified
FAILURE:
Unable to open datasource `fussgaengerstreifen.mdb' with the following drivers.
  -> OCI
:Stefan
2015-10-02 16:35 GMT+02:00 Stefan Keller <sfkeller at gmail.com>:
> Zoltan
> :Stefan
> 2015-10-02 15:48 GMT+02:00 Zoltan Szecsei <zoltans at geograph.co.za>:
>> Hi,
>> Look at http://www.gdal.org/ogr_formats.html
>> IIRC ogr2ogr needed that - but ogrinfo?  not sure - maybe the -oo param?
>> You could also use ogrinfo --formats
>> to see what's available on your system.
>> Hopefully others will chip in too.
>> Regards,
>> Zoltan
>> On 2015-10-02 15:38, Stefan Keller wrote:
>>> I have a similar issue and supposedly a very simple question:
>>> Given a file Geomedia .mdb file I'm getting a similar error on Windows.
>>> % ogrinfo myfile.mdb -al -so
>>> How does OGR recognize if it's a Personal Geodatabase or a Geomedia file?
>>> :Stefan
>>> 2012-03-28 16:19 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>> On Wed, Mar 28, 2012 at 3:57 PM, Zoltan Szecsei <zoltans at geograph.co.za>
>>>> wrote:
>>>>> Hi All,
>>>>> I am trying to find a way to list the data type of each field in all
>>>>> tables
>>>>> in a GeoMedia MDB databse.
>>>>> I tried ogrinfo mdbname and got:  ERROR 1: PGeo: MDB Tools driver not
>>>>> found!
>>>>> so, sudo apt-get install mdbtools, and tried again and got same error.
>>>>> so, sudo apt-get install gdal-bin and that gave me a newer version than
>>>>> that
>>>>> I did have.
>>>>> Interestingly apt-get returned:    Setting up gdal-bin
>>>>> (1.9.0-1~exp5~lucid4)
>>>>> ...... etc etc
>>>>> but afterwards:  ogrinfo --version still returns GDAL 1.8.1, released
>>>>> 2011/07/09
>>>> As you are on Linux, you should avoid the rely on ODBC, and use the
>>>> Geomedia driver [1], only available from gdal 1.9.
>>>> I would test it for you, but I have no Geomedia sample data for testing
>>>> p
>>>> [1] http://www.gdal.org/ogr/drv_geomedia.html
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Zoltan Szecsei PrGISc [PGP0031]
>> Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> P.O. Box 7, Muizenberg 7950, South Africa.
>> Mobile: +27-83-6004028
>> Fax:    +27-86-6115323     www.geograph.co.za
