[gdal-dev] Unable to compile Gdal under Cygwin
Dr Rainer Woitok rainer.woitok at gmail.com
Sun Oct 11 07:17:28 PDT 2015
On Saturday, 2015-10-10 16:31:50 +0200, I myself wrote:
>                          And lo and behold! the compilation succeeded.
Now on to testing: plenty of tests failing due to
   ERROR 6: Unable to load PROJ.4 library (cygproj-0.dll)
Well, the real  PROJ.4 library  is meanwhile named  "cygproj-10.dll" and
resides in a directory mentioned in  environment variable "PATH".  Where
does the name "cygproj-0.dll" come from?   Can I do something about that
(other than linking statically via "--with-static-proj4=...")?
Somehow I  don't quite  like the idea  of renaming my  PROJ.4 library to
what Gdal currently thinks is the right name :-(
Sincerely,
  Rainer
| Rainer M Woitok                | Phone : (+49 60 93) 487 95 95       |
| Kolpingstraße 3                | Mobile: (+49 172) 813 6 831         |
| D-63846 Laufach                | Mail  : Rainer.Woitok at Gmail.Com     |
| Germany                        |                                     |
