[gdal-dev] List of reasonable default parameters for each projection
Hermann Peifer peifer at gmx.eu
Sun Oct 11 19:40:03 PDT 2015
On 2015-10-11 21:09, Ray Gardener wrote:
> I was wondering if there is a list, for each projection supported by
> OGR, reasonable default values for each projection parameter. For
> example, if the user is switching projections in an app, a small table
> listing the projection parameters appears, but they need to be populated
> with reasonable default values.
> e.g. for the New Zealand Mining Grid, one could do
> spatialRef.SetNZMG(centerLat = 41, centerLong = 173,
> falseEasting=2510000, falseNorthing=6023150);
[peifer at moby:gdal]> pwd
/path/to/local/share/gdal
[peifer at moby:gdal]> grep 6023150 *.csv
pcs.csv:27200,"NZGD49 / New Zealand Map
Grid",9001,4272,19917,9811,1,0,4400,8801,-41,9102,8802,173,9102,8806,2510000,9001,8807,6023150,9001,,,,,,,,,
projop_wparm.csv:19917,New Zealand Map
Grid,9811,8801,-41,9102,8802,173,9102,8806,2510000,9001,8807,6023150,9001,,,,,,,,,
Seems easy, Hermann
