[gdal-dev] Reading JPEG2000 file related to drivers
Yves Jacolin yjacolin at free.fr
Tue Oct 13 08:04:19 PDT 2015
Hello,
On Tuesday, October 13, 2015 13:23:05 Yves Jacolin wrote:
> Do you know any limitation on jp2OpenJpeg? I get a segmentation fault with
> this driver:
> Here is the bt (from gdal 1.11, but get almost the same from trunk, line
> number is different):
Sorry to spam you :)
We tested with a jp2 file from autotest directory: 3_13bit_and_1bit.jp2,
OpenJpeg lib 2.0 and GDAL 1.11.
We had the same problem. Building gdal with debug mode we had the following
debug info:
GDAL: AutoSkipDriver(JP2ECW)
OPENJPEG: info: Start to read j2k main header (1427).
OPENJPEG: info: Main header has been correctly decoded.
OPENJPEG: nX0 = 0
OPENJPEG: nY0 = 0
OPENJPEG: nTileW = 202
OPENJPEG: nTileH = 308
OPENJPEG: psImage->x0 = 0
OPENJPEG: psImage->y0 = 0
OPENJPEG: psImage->x1 = 202
OPENJPEG: psImage->y1 = 308
OPENJPEG: psImage->numcomps = 4
OPENJPEG: psImage->color_space = 0
OPENJPEG: numResolutions = 3
OPENJPEG: psImage->comps[0].dx = 1
OPENJPEG: psImage->comps[0].dy = 1
OPENJPEG: psImage->comps[0].x0 = 0
OPENJPEG: psImage->comps[0].y0 = 0
OPENJPEG: psImage->comps[0].w = 202
OPENJPEG: psImage->comps[0].h = 308
OPENJPEG: psImage->comps[0].resno_decoded = 0
OPENJPEG: psImage->comps[0].factor = 0
OPENJPEG: psImage->comps[0].prec = 13
OPENJPEG: psImage->comps[0].sgnd = 0
OPENJPEG: psImage->comps[1].dx = 0
OPENJPEG: psImage->comps[1].dy = 0
OPENJPEG: psImage->comps[1].x0 = 202
OPENJPEG: psImage->comps[1].y0 = 308
OPENJPEG: psImage->comps[1].w = 1
OPENJPEG: psImage->comps[1].h = 1
OPENJPEG: psImage->comps[1].resno_decoded = 0
OPENJPEG: psImage->comps[1].factor = 0
OPENJPEG: psImage->comps[1].prec = 0
OPENJPEG: psImage->comps[1].sgnd = 13
OPENJPEG: psImage->comps[2].dx = 0
OPENJPEG: psImage->comps[2].dy = 0
OPENJPEG: psImage->comps[2].x0 = 1
OPENJPEG: psImage->comps[2].y0 = 1
OPENJPEG: psImage->comps[2].w = 0
OPENJPEG: psImage->comps[2].h = 0
OPENJPEG: psImage->comps[2].resno_decoded = 0
OPENJPEG: psImage->comps[2].factor = 13
OPENJPEG: psImage->comps[2].prec = 202
OPENJPEG: psImage->comps[2].sgnd = 0
OPENJPEG: psImage->comps[3].dx = 0
OPENJPEG: psImage->comps[3].dy = 0
OPENJPEG: psImage->comps[3].x0 = 0
OPENJPEG: psImage->comps[3].y0 = 0
OPENJPEG: psImage->comps[3].w = 0
OPENJPEG: psImage->comps[3].h = 0
OPENJPEG: psImage->comps[3].resno_decoded = 308
OPENJPEG: psImage->comps[3].factor = 0
OPENJPEG: psImage->comps[3].prec = 1
OPENJPEG: psImage->comps[3].sgnd = 202
OPENJPEG: Unable to handle that image (2)
Program received signal SIGSEGV, Segmentation fault.
0x000000000062faf0 in ?? ()
So gdal or the openjpeg lib mix information (check width and height for each
bands).
We updated openjpeg lib to 2.1 and gdalinfo worked as expected.
We will test gdal 1.10 with OpenJpeg 2.0 to check that the problem is already
there as we would like to use GDAL 1.10 but I am afraid we should use gdal
1.11 and OpenJpeg 2.1.
Y.
