[gdal-dev] gdal dll depedencies
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue Oct 13 13:32:15 PDT 2015
Gane R <gane.prog <at> gmail.com> writes:
> I have build gdal from source of the lastet stable release gdal-2.0.1.
Does all the drivers code go within gdal200.dll or any dependency exists ?
I would use Dependency walker for checking that. You will find loads of
dependencies.
-Jukka Rahkonen-
