[gdal-dev] [EXTERNAL] Re: How connect to a remote oracle with spatial
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Wed Oct 14 06:45:54 PDT 2015
Ivan,
I've never tried OS authentication.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: Ivan Lucena <lucena_ivan at hotmail.com<mailto:lucena_ivan at hotmail.com>>
Date: Wednesday, October 14, 2015 at 9:44 AM
To: Michael Smith <michael.smith at erdc.dren.mil<mailto:michael.smith at erdc.dren.mil>>, Jukka Rahkonen <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>, "gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>" <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Subject: RE: [gdal-dev] [EXTERNAL] Re: How connect to a remote oracle with spatial
Mike,
I think I also implemented OS authentication for both driver, OCI and GeoRaster. Have you used that?
Regards,
Ivan
> From: Michael.Smith at erdc.dren.mil<mailto:Michael.Smith at erdc.dren.mil>
> To: jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> Date: Wed, 14 Oct 2015 13:01:56 +0000
> Subject: Re: [gdal-dev] [EXTERNAL] Re: How connect to a remote oracle with spatial
> Note that you can also use what Oracle calls the ezconnect syntax which is
> user/pass at host:port/service_name. Then no TNS is needed. Also note that
> port only needs to be specified if its not 1521.
> Mike
> Michael Smith
> On 10/14/15, 3:56 AM, "gdal-dev on behalf of Jukka Rahkonen"
> <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of
> jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
> >Andrea Peri <aperi2007 <at> gmail.com> writes:
> >> Hi,
> >> I'm trying to test using gdal the access to an oracle dbms.
> >> To do this I use the ogrinfo and try this sintax but without success.
> >> ogrinfo OCI:username:password <at> "(DESCRIPTION = (ADDRESS_LIST =
> >>(ADDRESS
> >> = (PROTOCOL = TCP)(HOST = <IP server dbms>)(PORT = <listener
> >> port>)))(CONNECT_DATA = (SID =<the sid of dbms>))):<schema>.<table>"
> >> The server return
> >> ERROR 1: ORA-01005: null password given; logon denied
> >> in <unnamed>
> >Don'n you have a record for your connection in the tnsnames.ora
> >BlockedBlockedBlockedhttp://orafaq.com/wiki/Tnsnames.oraBlockedBlocked? If you have,
> >use @SERVICE_NAME with ogrinfo
> >Read also carefully the manual page
> >BlockedBlockedBlockedhttp://www.gdal.org/drv_oci.htmlBlockedBlocked
> >You wrote OCI:username:password but it should be
> >OCI:username/password at database_instance:table,table
> >As documented "ogrinfo OCI:username/password at database_instance" is enough
> >but at least in our environment it can take several minutes to read the
> >metadata from Oracle if table list is not given for limiting the search.
> >-Jukka Rahkonen-
> >_______________________________________________
> >gdal-dev mailing list
> >BlockedBlockedBlockedhttp://lists.osgeo.org/mailman/listinfo/gdal-devBlockedBlocked
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151014/3667175d/attachment.html>
