[gdal-dev] How to write WKB as string?
Even Rouault even.rouault at spatialys.com
Wed Oct 14 10:24:19 PDT 2015
Le mercredi 14 octobre 2015 19:18:20, Roger André a écrit :
> <grin>  Yes Even, exportToWkb() was something I tried, but I thought there
> might be an easy way to get the ASCII form of the WKB, rather than the
> straight binary that I got when I wrote out to a text file.
Ah I missed that part.
The following should help:
http://www.gdal.org/cpl__string_8h.html:
char * 	CPLBinaryToHex (int nBytes, const GByte *pabyData)
CPL_WARN_UNUSED_RESULT
 	Binary to hexadecimal translation. More...
GByte * 	CPLHexToBinary (const char *pszHex, int *pnBytes)
Even more compact with base64 encoding:
char * 	CPLBase64Encode (int nBytes, const GByte *pabyData)
int 	CPLBase64DecodeInPlace (GByte *pszBase64)
> Norman, thanks for the links. I'll go peruse them.
> On Wed, Oct 14, 2015 at 10:10 AM, Norman Vine <nhv at cape.com> wrote:
> > On Oct 14, 2015, at 12:59 PM, Roger André <randre at gmail.com> wrote:
> > Hi All,
> > I have a tool which currently exports geometry using the ExportToWkt()
> > function.  It works great, but I'd like to try reducing the size of my
> > output files by using a format like the string representation of WKB that
> > shp2pgsql produsces when creating SQL insert files.  Is there a export
> > function available in GDAL that I could use for this?
> > I'm looking at http://www.gdal.org/classOGRGeometry.html currently, but
> > have not yet spotted what I'm looking for.
> > Thanks,
> > see
> > http://www.gdal.org/ogr__api_8h.html#ad5c94ae76c09774dba8725c24daeefd6
> > or
> > http://www.gdal.org/classOGRGeometry.html#a9a3ad2f9b55285be500ca6ac5dc75d
> > 1d
http://www.spatialys.com
