[gdal-dev] GDAL precision for Geometry object
Even Rouault even.rouault at spatialys.com
Fri Oct 16 09:20:37 PDT 2015
Le vendredi 16 octobre 2015 17:57:10, Hermann Peifer a écrit :
> On 2015-10-12 11:28, Even Rouault wrote:
> > I've changed to '%.15g' formatting for WKT in
> > https://trac.osgeo.org/gdal/ticket/6145
> Hi Even,
> Why did you choose '%.15g', rather than '%.17g'? The latter format
> should guarantee a lossless binary->decimal->binary round-trip, whereas
> the former one might also do -- or not. I don't think that any precision
> loss between '%.15g', and '%.17g' would result into "a real life
> problem", I am asking just out of curiosity.
Hi Hermann,
re'adding the list in CC.
Your point is valid. My idea was to avoid making WKT returned by the modified
version potentially longer than it is currently
This should perhaps be configurable to accomodate for different use cases.
Even
http://www.spatialys.com
