[gdal-dev] gdal_polygonize.py not running
Giorgio Ghiggini gghiggini at gec-it.com
Sat Oct 17 01:50:58 PDT 2015
I am using the GISInternals “release-1800-x64-gdal-1-11-1-mapserver-6-4-1”
and I run the SDKShell.bat.
Then I tried running the gdal_polygonize.py as is and I got the following
message:
C:\GEC\Software\GDAL\gisinternals>gdal_polygonize.py
"gdal_polygonize.py" non è riconosciuto come comando interno o esterno,
 un programma eseguibile o un file batch.
In Italian, that means “command not recognized” so I thought the SDKShell is
not setting the path for this script.
I tried then running the command from the script folder as follow, but got
several errors:
C:\GEC\Software\GDAL\gisinternals\bin\gdal\python\scripts>gdal_polygonize.py
C:\GEC\Data\Slopes\testgdaldem-combined.tif -f "ESRI Shapefile"
C:\GEC\Data\Slopes\testgdalpolygonize.shp
  File
"C:\GEC\Software\GDAL\gisinternals\bin\gdal\python\scripts\gdal_polygoniz
e.py", line 34, in <module>
    from osgeo import gdal, ogr, osr
  File
"C:\GEC\Software\GDAL\gisinternals\bin\gdal\python\osgeo\__init__.py", li
ne 21, in <module>
    _gdal = swig_import_helper()
  File
ne 17, in swig_import_helper
    _mod = imp.load_module('_gdal', fp, pathname, description)
  File "C:\Python34\lib\imp.py", line 243, in load_module
    return load_dynamic(name, filename, file)
ImportError: DLL load failed: Impossibile trovare il modulo specificato.
To me it looks like the script is not able to load other external files
(gdal, ogr, osr
), so I still think it is a matter of PATH setting.
Any help is very much appreciated.
Best regards,
Giorgio
Giorgio Ghiggini
GEC di Ghiggini Giorgio
Via Monte Matanna 1/C
55049 Viareggio (LU)
Italy
P.Iva: 01381570116
cell.: +39 331 141 9315
email: gghiggini at gec-it.com
www.gec-it.com
 <http://www.globalterramaps.com/> www.globalterramaps.com
www.globalaquamaps.com <http://www.globalaquamaps.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151017/41c44b99/attachment.html>
