[gdal-dev] Refactoring: class members clean-up
Even Rouault even.rouault at spatialys.com
Sat Oct 17 03:54:46 PDT 2015
Le samedi 17 octobre 2015 00:25:45, Kurt Schwehr a écrit :
> I personally like foo_, but m_ is fine.  I worry about unexpected side
> effects of changing member naming with private members.  I don't think
> there will be any if everything builds, but I still worry.
There can be subtle effects indeed, so care should be taken.
Consider the following example (just for the fun) :
#include <stdio.h>
#include <strings.h>  /* const char *index(const char *s, int c); */
class foo
        typedef const char* (*ptrfnc)(const char*, int);
        ptrfnc index;
    public:
        foo() : index(0) {}
        ptrfnc getIndex()
            return index;
int main(int argc, char** argv)
    printf("%p\n", foo().getIndex());
    return 0;
==> Displays (nil)
Now let's rename index to m_index, but forget to change getIndex():
#include <stdio.h>
class foo
        ptrfnc m_index;
    public:
        foo() : m_index(0) {}
        ptrfnc getIndex()
            return index;
    return 0;
This still compiles without warning but displays 0x400548 ...
http://www.spatialys.com
