[gdal-dev] ARCSDE
ePascoal pascoal.egeo at gmail.com
Mon Oct 19 08:37:49 PDT 2015
Hi  gdal-dev,
*INTRODUCTION*
i'm pretty newbie in gdal. This question follows another issue  which as to
do with " How to migrate data from ArcSDE to PostGIS?
<http://gis.stackexchange.com/questions/12989/how-to-migrate-data-from-arcsde-to-postgis>
" And besides of my doubt about how to configure OGR SDE driver, i would
like to know your opinion about the process of migrate a ARCSDE database to
Postgis.
CONTEXT:*
So, in first place i have a Oracle 10g database with ArcSDE but
unfortunately i don't have access to SHAPELIB and other packages from ArcSDE
which would allow me to convert ESRI geom into string or another format that
PostGIS could understand as geometry type.
*SELECT* sde.ST_AsText(shape) as wkt *FROM* EXAMPLE_POLYGON_TABLE
So, this wouldn't be possible
*QUESTION*
1. Supposing that i have the following two jar files required according
geotools: *jsde_sdk.jar* and *jpe_sdk.jar*.* How can i configure this SDE
driver? *
2.After that, would be possible using gdal lib to read shape and convert
shape to wkt, so i can save this information on my postgis getting the
correct geometry?
Thanks in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/ARCSDE-tp5231174.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
