[gdal-dev] CS transformations
Even Rouault even.rouault at spatialys.com
Mon Oct 19 11:54:04 PDT 2015
Al,
> # get the dataset projection and wrap it with spatial reference
> source = osgeo.osr.SpatialReference()
> source.SetProjection (ds.GetProjection())
--> This is not the right method to call. SetProjection(string) is for
projection names like 'Transverse_Mercator', etc... but not full WKT
definitions
You want to use instead source.ImportFromWkt(ds.GetProjection())
> # build the spatial reference for WGS84
> target = osgeo.osr.SpatialReference()
> target.SetWellKnownGeogCS('WGS84')
> # make the transform to go between the CS
> transform = osgeo.osr.CoordinateTransformation(source, target)
--> You should have received an error message at that point saying there's no
translation for '.. a wrong WKT string ...' to PROJ.4
Even
http://www.spatialys.com
