[gdal-dev] OGR error handling
Ari Jolma ari.jolma at gmail.com
Wed Oct 21 00:13:27 PDT 2015
On 20.10.2015 22:20, Andre Vautour wrote:
> Hi all,
> We are using OGRSFDriver::CopyDataSource() to copy a GML data source
> to a memory data source on v1.11.x.
> We have encountered a problem where one of the feature tags of a
> particular GML file we are trying to read is malformed. What we are
> seeing is that an error occurs in OGRGMLLayer::GetNextFeature(), which
> gets reported as expected via CPLError().
> The problem we are faced with is that that error seems to be reset
> using CPLErrorReset() before control returns to the caller of
> CopyDataSource(), specifically in OGRDataSource::CopyLayer(). The
> result is that the copying silently skips over problematic features.
> Is that the expected behavior of copying a data source? Given that
> GDAL isn't necessarily exception safe, we've typically used
> CPLGetLastErrorNo after control returns to get at such errors that
> occur in functions that do not return an error directly in the method
> signature. Is there a better approach to error handling that we
> could/should be using?
If CPLError gets called then the issue is reported and it is not
silently skipped. I believe the driver writer has judged the issue not
an error but only worth of a warning, thus the GetNextFeature does not
return a NULL, which would lead to immediate return without error reset.
As Even wrote I guess you should make your code to keep an eye on
warnings and not accept the copy if there are any you deem too serious.
Ari
> Thanks,
> André
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
